Pull Mazda5 Headunit for XM FM mod intall
Old Aug 31, 2005 | 12:54 AM
andrewlwilson's Avatar
Default Pull Mazda5 Headunit for XM FM mod intall
Bought a Mazda5--love it! Exceeded all my expectations. It's my fourth Mazda . . . Anyway, I want to install a direct FM modulator for my XM Roady2. Any idea on how to pull the headunit to reach the plugs on the back?
Old Aug 31, 2005 | 04:21 PM
Patrick's Avatar
Administrator
Default RE: Pull Mazda5 Headunit for XM FM mod intall
are you sure that there are input ports?
Old Aug 31, 2005 | 05:11 PM
Do not rememer if has input port or not. Fairly easy to remove to check. Pull side panels down on inside of both footwell straight out. Remove the one visible phillips screw on each side. Pull the silver shifter cover straight up and remove. Two screws under this panel to remove as well. Now move shifter as far rearward as you can and pull the entire center console towards you and up. There are two clips in the upper center just below the a/c and recirc buttons that are kind of tight so be careful not to break console. Pull console out of the way and remove two phillips screws on bottom of audio unit. Pull audio unit straight out. Included some picts to show location of clips and screws.
[IMG]local://upfiles/1377/3157F8D465294B61947D388BAF63726C.gif[/IMG]
[IMG]local://upfiles/1377/03FC78F59E5B412184C11017073D1547.gif[/IMG]
[IMG]local://upfiles/1377/04291A926E0C4E279664BA43BFF96FF9.gif[/IMG]
[IMG]local://upfiles/1377/84C4B30DFEE44DDBADD443E9C6F74E66.gif[/IMG]
[IMG]local://upfiles/1377/C1BF32F4E5734AE1ADC8125B051F3FEA.gif[/IMG]
Old Sep 1, 2005 | 11:51 AM
Thanks for the very detailed reply--exactly what I needed!!
Old Sep 3, 2005 | 06:07 PM
Instructions for headunit are very accurate. And yes, there are inputs on the back for FM antenna. Thanks again!
Old Sep 4, 2005 | 05:03 AM
Glad I good lend some assistance in r and r.
Old Sep 27, 2005 | 01:15 PM
Trix's Avatar
I took may radio out too installed a DVD input and a BTL too change from cables to RCA at the output of the original radio a pre-amp and a four channel Amps for the 4 speakers [:@] but i had to take the 5 too the dealer so my proyect is in hold and i will continue when they fix the problem
martinrees
Jun 1, 2014 02:09 PM
reeroo33
Oct 3, 2009 11:33 PM
sbauer
Jan 8, 2009 07:02 PM
Pixie
May 18, 2007 07:56 PM
mazda3power
Aug 26, 2006 02:38 PM
