Easiest way to get power to the amp!!
Only works for Automatic!!!!!!
After searching the forum for a way to get the amp power wire to the trunk I could find NOTHING!!!!!!!
---Soo I had to go fishing!
1- Remove Battery and mount that batt sits on
2- Look for a oval looking piece of plastic where clutch would be. ( Behind batt on firewall- on inside- under steering wheel)
3- Find right size drill bit.
4- Drill thru ( You might need to drill from outside in and vice versa
5- Feed wire thru
6- Listen to your system bump!
Any questions let me know!!
5- Feed wire thru
ultrarevvin1
UltraRev
01-14-2014 10:24 AM
