detailing your engine bay...
i've always detailed my engine bay religiously (not to mention my exterior of my vehicle as well). but what i have found is an excellent write up of how to keep your engine bay clean with a little bit of work every few months or so.
http://www.guidetodetailing.com/arti...p?articleId=25
(*cough cough... a cleaner engine bay not only shows that you maintain your vehicle religiously, but also helps to keep the value of your vehicle up as a result)
RE: detailing your engine bay...
i'm a big fan of using an air compressor after i'm done detailing my engine bay just to blow off all the excess water... then what i do is wipe off the remaing parts quickly with a dry towel. then the rest is left to be sun-dried with the hood open in the sun for about 20 minutes or so.
Yeah I am glad to see a link like that one.
I have been looking for some more info on cleaning the engine bay.
I haven't really cleaned mine out to much because I wasn't sure what to use. Mainly I was afraid of using something that would eat at my hoses and any thing else that was rubber.
Too bad I don't have a hose, I guess I could just go to a car wash and just use one of the sprayers there, just keep it on a low setting.
Any tips on detailing metal? Any good rust removers out there? I have some little specks of spot rust on my heat sheald and I would like see if I can get them off of just keep the rest of the rust away.
simply, for you heat shield... you can sand that away. and for detailing metal, i'm not too sure what to use for that. maybe just wipe it down real good and wax a bit over it if you get it all prettied up nicely.
Types: There are different types of sandpaper, each has a specific use. Generally there are 2 categories of sand paper, wet and dry. Sand papers are primarily made of sand and/or silica and garnet, adhered to a ground of resin on paper.
Grades of paper: Sandpaper is manufactured in many grades, also known as levels of coarseness, or ‘grit’. The lower the grade, or grit of sandpaper, the coarser, and stronger abrading power of that paper.
Quick chart - Sandpaper
30 grit extremely coarse
60 grit Coarse
80 grit coarse - recommended for removing rust from metal, difficult dried paint areas
100 grit coarse - recommended for removing rust from metal, difficult dried paint areas
120 grit recommended for general purpose, drywall patches
180 grit recommended for general purpose, drywall patches
220 grit recommended for general purpose, furniture
240 grit recommended for general purpose, furniture
320 grit recommended for general purpose, furniture and first sand for fine finishing
400 grit recommended for fine finishing, polishing, gilding
600 grit recommended for fine finishing, polishing, gilding
800 grit recommended for fine finishing, polishing, gilding
1000 grit recommended for fine finishing, polishing, gilding
1200 grit recommended for hand rubbed finishes, fine finishing, polishing, gilding
1600 grit extremely fine. Polishing, jewelry
Sanding methods:
Knowing your intention for the finished product before starting will make it easier to properly prepare the item being treated. The common approach to sanding is to begin with a lower grit paper, or coarser paper, and increase the fineness of the sandpaper until desired results are achieved.
Metal:
Begin with loosening and scraping any loose paint or rust with a metal-toothed brush or coarse steel wool. Starting with a coarse grade of sandpaper move regularly over surface. Continue in this manner with increasingly finer grades of sandpaper until sufficient level of desired smoothness.
60 grit Coarse
Sanding methods:
Metal:
i whipe my engine compartmentdown after every wash, and dress the plastics up a bit. stays pretty clean, onsidering i wash my car maybe 2 times a week haha i cant stand a dirty car.
[IMG]local://upfiles/10860/00E43519E1B84CFAB85DE2D944680E3E.jpg[/IMG]
