Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
89-B2600 4X4
Old 09-21-2008 | 01:24 PM
JOBILISA's Avatar
Default 89-B2600 4X4
Need help
I have a 1989 Mazda B2600 4x4 I just did the clutch, and when i was driving it the truck started jerking and concked out. This issue is driving me craze, I changed the fuel pump (big job) but it didn't work. with the old pump we got 30 psi with the new one we get 40 t0 45 psi ?? is that good ??
seems that the problem is fuel not getting in. I opened the fuelreturn hose and fuel goes through.Fuel filter is new.
Please if anyone have an idea let me knpw
Thanks
Old 09-21-2008 | 10:22 PM
wsoape281's Avatar
Default RE: 89-B2600 4X4
do you mean that the fuel will not make it to the motor, but the pressure is still up? if so, i would check the regulator. i am guessing from the pressure and the year that it is TPI. if so, they may have slipped you the wrong part. one way to check the regulator is to pinch the return line at the tank, not at the motor, and try to fire it up. if it fires and runs, you need a new regulator.
Old 09-22-2008 | 09:04 AM
JOBILISA's Avatar
Thanks for your relply, I did pinched the return hose , but i did it just by the motor.
Do you know how much fuel pressure should I have? the old pump read 20 PSI, the "new one reads between 40 and 45 Psi.
Onother thing the trucks starts but conks out right away. If I pump the gas pedal really fast the trucks try to stat and kind of back fires. I kind of believe is somthing simple but hard to find.
Thanks again
i will try pinching the hose by the fuel tank.
Old 09-22-2008 | 09:30 PM
wsoape281's Avatar
40 seems kind of high, but i have seen pressures that high before for TPI. for carbed, that would be ridiculously high, but TPI needs a more constant flow (more returns than is used). i would go to another auto parts store and cross check the part that they show you as opposed to the one that you already bought.
2blue
Off Road
10-29-2012 01:26 AM
varbcorp
06-19-2006 02:43 AM
varbcorp
06-09-2006 10:26 PM
90B2600I
11-04-2005 10:37 AM
ABTireman
06-03-2005 03:09 AM
Quick Reply: 89-B2600 4X4
