Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
dpf removal without an ECU remap
Old 04-15-2013 | 08:02 AM
rmfinnie's Avatar
Default dpf removal without an ECU remap
Hi, i recently bought a 08 mazda3 1.6d takara and within 6 weeks the dpf was was totally blocked and the car pretty much shut down (cut out after 1500rpm) and the 2 pipes with pressure sensors blew.
So, my mechanic removed the dpf honeycomb with hammer and chisel, put the dpf back on and now everything seems to be ok and no EM light etc WITHOUT A REMAP. However, i fully expected that the car would go into limp mode and EM light would come on straight away but it hasn't...yet!!
So, i fully expected that i'd need a remap and have budgeted for this, but, just wanted to know is the remap actually essential after a dpf removal (and if so or not why) for the car's health and longevity??
All feedback, opinions and info would be much appreciated
Richard
Old 04-17-2013 | 08:11 AM
rmfinnie's Avatar
anyone??
Old 04-17-2013 | 08:48 AM
Vehicle Tech's Avatar
Default DPF Removal
Hi
Yes in time the dpf light will come back on, you will need to get the ecu remapped.
because you've removed the dpf the car will try to regen all the time & dump the fuel in the oil
keep eye on your oil level, hope this helps
Regards
John @ Vehicle Tech
vehicletech.uk.com
Old 04-18-2013 | 05:23 AM
rmfinnie's Avatar
John,
Many thanks for your reply, just a further 2 questions:-
1. Now there is much less back pressure why haven't the pressure sensors immediately picked up on that and either sent the car into limp mode or turned EM light on?
2. When you mention regens do you mean passive or active? Wouldn't an active regen only occur when either the pressure reaches a certain level or the dpf is clogged at a certain level (eg. 50%)? But with no dpf at all the pressure should never increase and the dpf is 0% clogged. My car will rarely perform passive regens too as my daily commute is only a 15mile round trip.
Regards
Richard
Old 06-25-2013 | 07:02 AM
sophietang's Avatar
plug under the hood. DPF diesel particulate filter can be modified or removed without causing any errors or abnormal car behavior.Emulator is completely controlled and interfaced with our software via USB cable and dongle, which allows to modify,optimize DPF FAP settings for different ECUs.
kimpetit
08-21-2021 06:53 AM
rmfinnie
04-17-2013 08:13 AM
rmfinnie
Intake, Headers and Exhaust
04-17-2013 08:12 AM
vaughan143
12-06-2009 05:57 AM
