1974 929 starting problem
i have a 1974 mazda 929 sedan and it wont start, wont even kick over.
power is getting to the starter as its clicking but it wont spin, it has been doing this a bit lately but has been kicking over till now, nothing at all will happen.
any help is appreciated
RE: 1974 929 starting problem
If you turn the key to the start position and you hear a click,determine if the clicking is coming from the starter motor or a relay.If it is coming fromthe starter motor and you know the engine is not seized replace the starter.That is normally a sign the solenoid is engauging but not sending voltage to the starter motor,or the starter motor has a burned armature,either way replacing the starter should take care of this.
