2006 mazda 5 code 2187
Old 12-22-2011 | 01:33 AM
goatboy0067's Avatar
Default 2006 mazda 5 code 2187
here is the problem i fill the tank its becomes hard to strat only right after filling also the check engine light goes off for a bout a quarter tank them comes back on, also has stalled at stop some times not everytime but often. any help would be appreciated thanks
Old 12-22-2011 | 11:16 AM
tanprotege's Avatar
The code says it is a lean condition. Either you have a vacuum leak, a dirty MAF sensor, or a fuel delivery problem. Or a combination of them. I guess it is a fuel delivery problem since it works alright when the tank is full.
Make sure the tank is properly vented, try a Gum Out fuel injector cleaner that has lubricants for the pump etc, and check for vacuum leaks in particular at hose connections, loose hoses and such. If that doesn't help check fuel pressure, change fuel filter, in a real bad case you may need a new fuel pump.
Did you ever run out of gas?
Good luck.
Old 12-22-2011 | 12:06 PM
lnwlf's Avatar
This is a coincidence... one of my co-workers has a Suzuki XL-7 (06 or 07) and is having similar symptoms so I told him I would check the web to see what I could find out. It appears on these Suzuki's the purge valve solenoid goes bad after 100+ thousand miles. here is the link to the thread I came across.
06 XL-7 Purge Valve defective - Suzuki Forums: Suzuki Forum Site
I'm not saying this is the problem, after all it could be something as simple as a bad gas cap. Just something to consider...
meme2005
05-26-2023 06:26 AM
kawaxi
02-25-2015 10:58 AM
Baston-Rob
12-25-2011 05:48 PM
Blunden0024
10-22-2010 09:10 PM
Bobbygian
09-30-2010 10:07 AM
