5 manual trans fluid change
RE: 5 manual trans fluid change
Yes, it's a 24 or 26mm hex. That's a tough lil' bugger to fill though, so make sure you have a good long, preferably clearhose to do it with. And the tranny (5-sp) takes 3 qts. so you need a fairly big drain pan/bucket too.
Unless you're switching over to synthetic though, there is probably no reason to waste the $$$ and time on it. How many miles on the 5?
