93 626 Starts Only When Air Filter Cover Is Open??
Old 01-25-2008 | 11:19 PM
hank's Avatar
Default 93 626 Starts Only When Air Filter Cover Is Open??
Hello,
My 1993 626 4cyl.sometimes does not start.
The "no starts" occur randomly.
I can get it to start when this happens byopening the air filter cover.
When I do that it cranks smoothly and starts up fine.
Then I re-clip the the cover and off I go and it drives fine.
I have changed the air filter.
I have checked the plugs they are dry and in good condition
I have tested the battery and it is in good condition.
I have done a general inspection and all vacum hoses and electrical wires appear to be tight and properly connected.
I have added gasline antifreeze as well.
It is now winter where I am, somevery cold temperatures (-20 celcius etc...)maybe that will provide a clue.
Keep in mind that sometimes it just starts up like a charm as it has for the last 14 years
Anyone have any idea whatpart or parts I shouldinspect and test?
Any help is much appreciated.
Thanks
Old 01-25-2008 | 11:56 PM
hank's Avatar
Default RE: 93 626 Starts Only When Air Filter Cover Is Open??
Justsome infothat I forgot to add:
The "no start condition" is no crank at all. Just the click of the starter solenoid and the dash lights come on, otherwise total silence.
Also My first post so a big hello to all !
Thanks again
Old 01-27-2008 | 12:51 AM
hank's Avatar
Hello,
I did some more testing today and it appears to be a coincidence that it started up with the air filter cover removed.
After testing, I think it is the starter itself and I am going to change it.
I must tell you it is a big job getting to that starter on a 93 626 4cyl automatic.
You have to remove the air intake assembly and manifold as well as the fuel rail and injectors.
I am just about done getting it out, one more bolt to go and then we start to put it back together again!
DjSlickSVG
01-27-2014 11:29 PM
howardstevens
03-19-2012 12:56 PM
packerfaninva
03-02-2008 03:14 PM
leftygolfguy
11-30-2007 08:55 AM
spiderpig
08-11-2007 08:23 PM
Quick Reply: 93 626 Starts Only When Air Filter Cover Is Open??
