'96 626 Tranny Issue
Old 04-28-2008 | 11:51 AM
bdawg17's Avatar
Default '96 626 Tranny Issue
Hi,
I'm experiencing some tranny issues and if anyone has any troubleshooting ideas I'd really apprciate some help.
I'm experiencing these issues in 5-10 minute spurt while driving on the freeway. My tranny seems to be downshifting into a lower gear. It will bounce back in forth between the correct gear and lower gears. My engine will be running around 2,750 RPMs and then bounce up to 3,500-4,000 RPMs and then fall back down.
Some simple and likely necessary maintenance fixes would be to flush the tranny fluid and change the filter. Other issues that I can come up with might be a belt, module, or governor issue.
If anyone has experienced this or has any ideas I'd appreciated you throwing them my way. Thanks!
-Brady
Old 05-04-2008 | 09:14 AM
626racer's Avatar
Default RE: '96 626 Tranny Issue
yeah it definately sounds like the filter, i'v driven so many vehicles that would do that, especialy around 55-65mph they drop into a lower gear and stay there for a while,but when you give it a bit more gas they bump back into correct gear, deff change the filter and fluid and you should be all set
b6t323
03-28-2013 01:10 PM
Resef
11-08-2009 06:48 PM
bdawg17
04-28-2008 11:51 AM
AlyssaC
01-12-2006 06:20 PM
AlyssaC
11-16-2005 06:49 AM
Quick Reply: '96 626 Tranny Issue
