97' 626 "Smokin"
Old 06-15-2007 | 01:15 PM
blenster's Avatar
Default 97' 626 "Smokin"
I have a 1997 Mazda 626 with 84,000 miles on it (LX). Everythime I start it (almost everytime) after it has been sitting overnight or for a long time, it shoots out a huge cloud of grey smoke! It goes away fairly quickly after I start driving, but if I just sit there it smokes. Anyone know what the deal is?
Old 06-15-2007 | 09:15 PM
mazzfan's Avatar
Default RE: 97' 626 "Smokin"
it is usually caused by a clogged air filter; mazda carburetor, choke, fuel injection or emission system malfunction; ignition timing off; or a blocked manifold. so I suggests that you check on those things. give us an update of what other things did you find out. good luck
Old 06-16-2007 | 03:22 PM
shiny6's Avatar
Valve stem seals which are worn usually allow oil to run down into the cylinders after shutting the car down. It'll smaoke on start-up, but the smoke will go away after a few seconds, and you won't notice much of an oil loss because it doesn't take much oil to cause a considerable puff of smoke. Probably not worth fixing until you replace the camshaft....if you ever get to that point.
Old 06-19-2007 | 08:44 AM
Sirob's Avatar
Blenster, if you have not done that for a long time try to replace fuel filter and clean injectors – I know at least one guy whom it helped to completely beat start-up smoke, but he had white smoke, not grey.
Roy
08-04-2010 07:50 AM
626v6
04-22-2010 09:00 PM
blan
05-13-2008 12:15 PM
NewGuy181
05-14-2006 03:44 PM
doormizzles
04-02-2006 09:16 PM
Quick Reply: 97' 626 "Smokin"
