airbag light flashing
Old 12-28-2006 | 02:33 PM
ppd121's Avatar
Default airbag light flashing
My airbag light is flashing. I don't want to sound like a dumb blonde, but here goes. It is flashing...5 flashes, pause, then 1 flash, pause and then 5 flashes and on and on. My question is this.....will my airbag deploy while driving? It is freaking me out. I have a 1994 Miata - automatic.
Old 12-29-2006 | 08:40 PM
babyhuey's Avatar
Default RE: airbag light flashing
Contrary to being a dumb blond, you are even smart enough to make a note of the flashing pattern.
No the air bag will notdeploy while you are driving. The system is shut down if a fault is detected and light is flashing. The flashing pattern you describe is a code 51 which would indicate a burned system down fuse within the air bag diagnostic module itself. Somewhat of a common problem with mid 90's MX-5. New module should get you squared away but will run you around $170 from the dealer. Am sure you could get cheaper an onlinemazdaparts.com. OE part number for the diagnostic module is GA2A-67-7F0A
Old 12-30-2006 | 10:36 AM
ppd121's Avatar
Babyhuey,
Thank you for your response.....very much appreciated. Happy Holidays!!!!
Old 12-31-2006 | 05:41 AM
babyhuey's Avatar
Glad to be of some help. Happy Holidays to you as well!!!
Diamond02
05-30-2014 02:36 PM
djn
10-09-2011 04:00 AM
nickyplumb
10-14-2008 02:02 PM
whitecolamazda
04-12-2006 01:30 AM
jjalilvand
10-21-2004 06:50 PM
