brake pads and rotors
Ummmm... Out of State? (I'm 'trying' to be funny.)
No, I don't know for sure. I used to live in Pa and work in NJ, but I don't know much about north Jersey... except that Jersey City and Newark live there. Well, on the eastern side at least.
Just do them yourself, they're not that difficult. Is it any similar to the MX-3/Protege type setup? Because if it is then there's an easy how to guide I have about it:
http://mechdb.com/index.php/Ford_Esc...ad_replacement
I just tried searching for one for the 6 but only text guides showed up. If you do it, take some pictures to share with us .
The concept is pretty much the same on all cars.
Sticking caliper slides are probably to blame. This is what allows the caliper to slide and wear the pads and rotor evenly. When brakes are applied and released the caliper is not allowed to float causing brakes to squeal or grind. May sound like rocks with cheaper pads due to elevated pad temps.
mazpro00
09-07-2014 03:04 PM
ultrarevvin1
UltraRev
01-14-2014 09:31 AM
