brake problem
Old 07-13-2006 | 07:34 PM
james1's Avatar
Default brake problem
i have 87 b2200 put new slavecilender in clutch was fine for 2 weeks now pedal goes to foor and fluid bowel is emty after 15 minute ride cant find leak any help would be nice
Old 07-13-2006 | 11:34 PM
babyhuey's Avatar
Default RE: brake problem
If the resevoir is going dry then has to have a leak somewhere. It certainly does not evaporate that fast. Pull back the slave cylinder boot and see if fluid runs out. Also carefully check the firewall both inside and out where the master cylinder bolts up to see if it is leaking. If all of these are dry then a line is leaking somewhere.
kgzak
08-07-2015 01:23 PM
schlompie
03-06-2012 03:49 PM
mtarajia
05-15-2007 03:24 PM
rak
08-02-2005 12:52 PM
mainman2c
07-21-2005 03:19 AM
Quick Reply: brake problem
