car runs great but the freking engine light is on
Old 02-09-2006 | 09:36 AM
oldmangt96's Avatar
Default car runs great but the freking engine light is on
bougt car for fun, its a probe gt it had a engine light on so i scanned it. Code came up p 1195 go to first step tune-up so i did that .Reset the light light comes on in two days rescan it says erg valves are bad replace them reset light comes on in two hours says random missfires so i check the wires and in the head sleeve i find fresh oils so i clean it DRive for three days the oil is back but the car drive and runs great ,a little fast on idle 1140 and the dame light is on again can u help me im not haveing to much fun with my new toy.
Old 02-09-2006 | 10:52 AM
sstlaure's Avatar
Default RE: car runs great but the freking engine light is on
Where is the oil coming from? What you may want to do is this...
Clean the engine really well, make sure to get any excess oil off so that when you find some oil, you can figure out where it is coming from.
To make it easier to spot the leak, there is a phosphorescent (glows under blacklight) additive that you can put in your oil. After cleaning the engine really well, add that stuff to your oil and let the car run for a little while. Then get a blacklight under the hood (helps to do this in a dark garage). You should be able to see where the leak is coming from.
Old 02-10-2006 | 09:35 PM
bkey71's Avatar
The code you are getting is the EGR BOOST SENSOR. Not an EGR Valve flow problem. I cannot say where it is at on a Probe. On a 96 626 4 cyl it is on the passenger side of the engine. On the oil leak on the spark plug wires, if the plugs go deep down the center of the valve cover, you need to replace the valve cover gasket and spark plug hole seals...these will come in the kit.
mazdampvmama
12-22-2012 04:21 AM
CarlH
05-24-2011 04:23 PM
nastynate
01-02-2007 07:55 AM
Eric
03-28-2006 04:18 PM
