check eng...light on
Old 05-08-2007 | 08:10 AM
palunga's Avatar
Default check eng...light on
I went to check (engine light on) and i was ask to come back very bussy. on the mean time i checked my radiator level and found the antifreeze dirty like some sort of oil type on surfes when you open cap is this someting to werry about? Thank's palunga
Old 08-18-2007 | 10:57 AM
626_in_mo's Avatar
Default RE: check eng...light on
palunga,
How old is the car? Has the anitfreeze ever been changed? If not, I would suggest that you have the system flushed and have new anitfreeze added. I don't know if that's why you check engine light is on or not. A bos O2 sensor will cause the light to illuminate. Also, if you don't put your gas cap back on tight, this will cause the light to come on. Hope this helps,
David
Old 08-18-2007 | 10:59 AM
626_in_mo's Avatar
I meant a "bad O2 sensor", not a "boO2 sensor) SOrry[&:]
indranghimiray
07-28-2010 05:53 AM
wldturkey76
09-02-2007 10:19 PM
hawaiiboy
11-09-2006 11:39 PM
95MazMillS
10-15-2005 12:42 AM
Desmus
09-08-2005 06:07 AM
