Cigarette Lighter, 2000 Protege: help!
Old 05-11-2008 | 03:25 PM
pmorjal's Avatar
Default Cigarette Lighter, 2000 Protege: help!
Well, best as I can figure, there is no fuse for the cigarette lighter (which isn't working).....is there some sort of fusible link behind it? If so, anyone know how to get to it? Thanks for any info!!
Old 05-29-2008 | 02:46 AM
Mathew_lincoln's Avatar
Default RE: Cigarette Lighter, 2000 Protege: help!
The girlfriends capella had a soft wire connection to the centre terminal of the lighter socket. You pull out the socket and check continuity between the terminals and the centre terminal. I think its there as a simple thermal overload, gets too hot and melts so no more current, rather than starting a fire in the dash. We replaced ours by soldering in a piece of solder. It seems to work. May be safer just to replace the socket though.
Old 11-11-2008 | 06:01 PM
proteg321's Avatar
actually i do belive there is a fuse for the cigarette lighter under CIGAR in the interior fuse panel, ur fuse might be blown.... (what i think)
demille
12-27-2008 04:46 PM
andy301069
03-28-2007 02:55 AM
Ivy
01-08-2007 07:55 AM
rcrichton
08-03-2006 10:20 PM
arillas
07-27-2006 05:47 PM
Quick Reply: Cigarette Lighter, 2000 Protege: help!
