coolant in oil, HELP
hey hey, im new to this....so....ive been collecting rx-7's since i was 14, but i still dont know all that i need to know of course, but yeah...i recently bought a 1987, well october of 86', turbo II for 300$, and it runs but it leaks coolant into the oil, i have been told that it might be a busted water jacket, but i have no idea what the hell it could be, so if anyone has any reasonable explanation of what it might be then hook me up, because i figured if it was a busted water jacket it would leak into the combustion chamber and cause the motor to missfire, but yeah plz help
RE: coolant in oil, HELP
ther are rubber "O" rings that seal water jackets from combustion chambers. the rings are the size of the rotor housings and and when they fail due to age or over boost, allow water to enter places it should'nt go, ie. combustion chambers and oil supply. the engine needs to come apart to be repaired, so buy a complete gasket set and rebuild. good luck.
Stevoh
06-21-2010 04:17 AM
Coolant tank is going empty so fast!!! What the connection between coolant tank and the water pump??
firstquality
01-01-2008 10:04 PM
