Engine power problem
Old 04-03-2011 | 07:29 PM
jezjacob's Avatar
Default Engine power problem
Hiya
I have a V registered Mazda 323 Aegean (11 years old-91,000 miles on clock) which has a recurring problem where it keeps kicking back at you and loses power. This happens pretty much at any speed/revs and you have to depress the accelerator to get through it. Its almost as if fuel isnt getting through properly but the car has an inline fuel filter.
Ive changed all plugs and spark leads but no improvement.
Can anyone suggest anything?
Old 04-29-2011 | 11:33 AM
Master P's Avatar
Possible fuel pump fault . The filter is built into the pump unit.
Old 04-29-2011 | 12:06 PM
955iDaytona's Avatar
I'd have to agree, sounds like fuel pump. She's starving for fuel as you lay into it but once you've backed off it regains itself. Try cleaning or replacing your injector's as well, 90k sounds like they're due.
Old 04-29-2011 | 01:07 PM
shipo's Avatar
Changing fuel injectors after only 90,000 miles? Why would you want to do that?
Old 05-01-2011 | 08:14 AM
Master P's Avatar
I wouldnt replace the injectors just replace the part thats needed no need to replace the whole car . Let us know if it fixed the fault please.
Old 05-03-2011 | 02:16 PM
Exclamation
If you read the first part it said to clean the injectors...... 90k miles is 144,000 kms which for alot of vehicles can be be half of there engine life. It was just a suggestion. Good Luck
Old 05-03-2011 | 03:12 PM
shipo's Avatar
I'll have to ask again; what does a half engine life have to do with cleaning or replacing fuel injectors? Unless any given car spends a huge percentage of its operating life in a dusty environment, it is almost a sure bet that all of the injectors will outlast the engine and still operate within spec. All that without ever once cleaning or replacing them.
imurphy
09-04-2010 01:02 PM
x0054
03-08-2008 10:37 AM
diamondpack
12-04-2006 12:07 AM
ggotx
10-23-2006 01:06 AM
needforSPEED6
09-27-2006 11:50 AM
