fuel trim and misfire code?
Old 11-20-2009 | 09:47 PM
schmigal10's Avatar
Default fuel trim and misfire code?
i have a 98 protege DX. the check engine light came on shortly after i put gas in, its not the gas cap. i put in dry gas and injector cleaner because i thought it was the gas at first.
the codes reading cylinder 3 misfire and fuel trim malfunction. i replaced the plugs because they were fowled, although they will probably need it again if i dont get the misfire fixed soon. that didnt do the trick. any other ideas on what might be causing the fuel trim to be off?
Old 11-22-2009 | 12:02 PM
NightSwimmer's Avatar
Many possibilities...
Oxygen sensor, MAF, leaks in the intake airstream or the exhaust manifold among others.
silverstreaks
07-10-2009 04:20 PM
Sanjeevnuts
06-10-2009 07:23 PM
pnyklr
03-06-2007 04:05 PM
CardsFan420
11-08-2006 06:25 PM
cuyuni
03-20-2006 03:30 AM
Quick Reply: fuel trim and misfire code?
