Gas Cap
Gas Cap
Ok, My check engine light has been comming on. I changed the EGR valve and sensor and it came back on. BTW, I have a 99 Miata. I was told it could be a loose gas cap. How do you know it's tight enough? Is it tight when you start getting clicks or do you have to turn it several times when you start getting the clicks. I want to rule out a loose gas cap.
Thanks
Thanks
