general oil question
If your car has (and always has had) non-synthetic oil, 127k miles, would it be better to switch to synthetic or stick with non-synthetic?
Trying to keep the question broad (as I don't own a mazda), I didn't think it'd matter from car-to-car except for mileage.
There are a number of products on the market that claim to be able to clean junk out of an engine (you pour them in, let the engine run and/or drive it for a while and then drain the oil). That said, after turning lots of wrenchs over the last thirty some years, I've never seen even a shred of evidence that suggests that any of these treatments work (in spite of the glowing reports from many folks who swear by them).
I see. I've also heard (someone from autozone told me this) that switching between the two might affect valve timing or distance or something? I didn't really see how oil type could affect that, but they know more than I do.
Also, ever heard of a fumoto valve? Any input on those, they worth it?
http://www.quickoildrainvalve.com/
I changed over to synthetic in my old Honda after 60k. Drove it till it rusted out from under me @ 187k w/oil changes every 10-15k. The engine never came apart. It still ran like a top.
Changed over in my current Mazda @ 19k w/changes every 10k and so far (46k) so good.
The molecules of synthetic oils are smaller than conventional oils, therefore it will find any minor leak and make it seem as if it's gotten worse. The same if your piston rings, valve seals or guides are wearing. It will more readily find its way into the cylinders and be burned. In short, it can cause you to think you have more problems than you had before, but that too is a wives tale. They were already there.
As for the valve, I don't personally know any one using them. My only concern would be how restrictive is it and will all the oil be allowed to drain properly?
wow
that oil extractor is actually pretty sweet...just really expensive...a lot more expensive than my big ol pan.
I'll try switching to synthetic next change. Hopefully it'll warm up soon.
And thanks for the head's up virg, that'll certainly help reduce the imminent fear from problems and at least give me an idea of what just happened
