getting door panel off. HELP
RE: getting door panel off. HELP
Ok well you should just have three or four screws in the handle and the arm rest looking thing. Then after that you just pop the door panel off. It has those button things so just pull on the edges (very carefully) and it should just pop it off. I mean I have a 92 323 and I figure its pretty much the same.
I hope that helps I don't have a digital camra other wise I would show you pics of when I took mine off.
I hope that helps
I hope that helps
In order to remove the window crank , there is a hidden horseshoe shaped clip. This clip is located right behind the center of the crank handle where it enters into the door. The best tool to use can be bought at most part stores. Look in the "HELP!" section where the tools are at. It is called GM window crank removal tool. It is a flat tool about 5" long and has a "U" shaped end that will engage the clip to remove it. ALSO be careful not to lose the clip when removing it.
CharlyFh
02-02-2014 08:53 AM
