Gurgling sound.... Flickering lights...
Old 10-02-2005 | 12:26 AM
DayOh257's Avatar
Default Gurgling sound.... Flickering lights...
I tried to start up my Miata for the first time in three weeks. When I went to start it, the battery was dead. No sounds, no lights, nothing. So I go and jump start it, which it does on the first try.
Then the lights start to flicker...
I rev it up and the flickering goes away, but as the RPM's drop, I hear a gurgling sound from the intake, as if it were underwater and the lights flicker again.
If the revs are up, the lights are bright and everything is normal, but when I let up on the throttle, it gurgles and all the electricals flicker again.
Thoughts?
Old 10-02-2005 | 09:58 PM
bkey71's Avatar
Default RE: Gurgling sound.... Flickering lights...
Does it idle like normal while lights are flickering? First thing I would check is the voltage and amperage coming from the alternator. Does the battery hold a charge after running for a while and start back up? Next I would check the condition of the battery. Are the battery connections good? Possibly a ground too.
Old 10-03-2005 | 12:16 AM
babyhuey's Avatar
Keep in mind that your alternator does not operate very well at idle. The rpm's are too slow for it to output not only a good amperage level but also hard for it to maintain a good voltage. If your battery was completly dead then either let the alternator get a good charge on the battery or better still use a trickle charger to get battery back to charge. The gel batteries used in the Miata are somtimes a little difficult to recover from a full discharge. A slow charge for at least 12-24 hours will usually restore. Get the battery back up to a normal charge level before worrying about any flickering lights or gurgle noises. I think you will find both of these problems will go away once the battery is back to normal.
sharon54
05-15-2009 12:53 PM
04Mazda3Sport
12-26-2008 05:28 PM
JoeBlow
05-12-2007 11:53 PM
CXRabbit
12-23-2006 12:58 AM
ablanchard
11-06-2006 09:36 PM
Quick Reply: Gurgling sound.... Flickering lights...
