If I say misfire on #2 and no fuel trim?
What is the first thing that comes to mind, 96 Probe GT 2.5 V6?
It's not plugs, wires, cap, rotor, TPS, coolant temp sensor, crank position sensor either! I replaced all of those.
I would think bad or dirty injector/vacuum leak on that cylinder/clogged egr port. Does it actually miss? I would throw a bottle of Techron in the gas tank the next 2 tanks to decarbon and clean the injectors. Check all vacuum hoses.If it is isolated to #2 cylinder it should'nt be that hard to find the problem.
CardsFan420
11-08-2006 06:25 PM
