just a few questions
Old 11-09-2006 | 03:34 PM
supermanwithheat's Avatar
Default just a few questions
i own a 93 mazda mx6 v6. i was wondering what grade of oil should i use? it has 175,230 miles on it i believe. And also my left turn signal doesnt come anymore it just clicks real fast, i checked my front bulb and its good, but i cant get the tail light of the back to check it, how do i take of my tail lights?[&o]
Old 11-13-2006 | 02:33 AM
dentinger's Avatar
Default RE: just a few questions
im not sure how they come out, but i would have to say a couple a screws.
we've seen this problem a couple of times in my auto class....try seeing if its just the light bulb holder thing.....try switching the two sides and if the oter side doesnt work you found your problem....do you get what im saying??
as for the oil, i dunno, my car's brand new, but i would have to say maybe use high mileage oil?
Old 11-14-2006 | 04:02 PM
I dont really understand what you are talking about when you say .....try switching the two sides and if the oter side doesnt work you found your problem...., in my tail lights, there are some black plastic sort of lock look alike things, i've tried to pull those out because from the looks of it, it seems to me that is whats holding the tail lights in place of some screws. thanx for trying to help though
Old 11-14-2006 | 11:45 PM
bkey71's Avatar
On my car there is an access panel inside the trunk to get to the bulbs. I'm not sure how yours is put together though.
As for the oil, it depends where you live and the climate. I live in south Texas and I run 20W 50 year round with no problems.
Old 11-16-2006 | 03:43 PM
you said acces panel, i check that out. For the oil, i use the same grade i only asked cus i thought i was using something outrageous
Old 02-11-2007 | 05:53 PM
mmt's Avatar
mmt
take the screws out and slide the light assembly sideways towards the outside of the car. i just give it a little tap to release the lock
twowheels012
03-03-2014 07:39 PM
mjc79
12-09-2008 10:40 PM
mike13928
11-28-2008 12:27 PM
~Islander~
06-28-2006 03:41 AM
DarrylLeeOHS30
03-18-2006 10:33 PM
