Mazda 323 - starting problem
Old 05-16-2007 | 09:34 PM
rainman2736's Avatar
Default Mazda 323 - starting problem
I replaced the ignition switch but there is a continued problem with the starter continuing to run after the switch is tuened off. Also the run circuit does not seem to energize. Does anyone have an idea about the solution? Could it be the starter relay switch? Does anyone have a wiring diagram?
Old 05-25-2007 | 03:28 AM
mazzfan's Avatar
Default RE: Mazda 323 - starting problem
hmm.. it could be the starter relay.. you may start looking for vacuum leaks. also it might be because of some poor grounding or some loose connection. check also idle control valve and rubber pipe from the mazda air filter to the throttle body. try to check on these things. inform us if you notice other things..
Old 05-27-2007 | 11:07 AM
Ash's Avatar
Ash
I agree,
I'd definatly check out the things listed about. My bet is the relay
Greg6721
02-21-2020 01:50 AM
irhumbled
12
02-24-2010 07:44 AM
SethK24
02-13-2010 05:00 AM
sc0rpi0n
04-15-2007 03:13 AM
candlemine
05-06-2006 07:28 AM
Quick Reply: Mazda 323 - starting problem
