Mazda 6, jumping 5th after hitting kerb HARD
Old 03-12-2015 | 05:33 PM
wayne Sangwell's Avatar
Angry Mazda 6, jumping 5th after hitting kerb HARD
I have a 2005 Mazda 6 Diesel Estate, last week I was forced into a high kerb at about 40mph. This damaged my cv joint and driveshaft. The cars is now jumping out of 5th gear? Any idea what's happened. I have had the cv joint and driveshaft replaced.
Many Thanks
Old 03-13-2015 | 06:44 AM
Time for a new gearbox or a rebuild.
Old 03-13-2015 | 08:39 PM
hixx's Avatar
Was the car in 5th gear when it hit the curb? The possibilities are a broken cable end bushing not allowing enough travel to lock 5th in. ( Not likely not as it would probably jump out of another gear also since the same cable controls another gear) Although the cable would be pushing on the opposite side of the cable bushing sooo. Depends on how it broke. The spring in the hub sleeve that holds the dogs popped out of a dog. ( partial disasembly and trans removal required). A damaged 5th gear hub sleeve/synchro. The cable end bushings would be the first thing I would check. Just for general info I can tell you that the most common cause of a trans popping out of 5th is a worn out hub sleeve and fork due to the driver resting his/her hand on the shifter while driving. The hub is turning as your driving and that eats them slowly until they don't have enough reach to fully engage 5th.
mattpharding
03-11-2023 11:01 AM
Stotty
11-09-2010 02:14 PM
phearly
10-12-2008 04:13 PM
rrdo
01-28-2008 09:45 AM
rrdo
01-28-2008 09:45 AM
