Mazda 6 - Problems starting
hi everyone,
i have a new mazda 6 and when i leave my car out on a hot day, it has problems starting right away. when i turn the ignition key, i hear the cranking noise (like when you hear if you have a dead battery). it only starts after 15minutes of trying. has anyone experienced this problem? any help would be appreciated.
thanks
thanks
RE: Mazda 6 - Problems starting
have you checked the starter or battery? there are lots of possible causes why it won't start: No petrol, no fuel pressure, injectors not being fired, no ignition spark - it could be because of a bad ignition coil or bad rotor arms, or there is a dirty connections. try to look on these things. a friend of mine had problem starting, after inspecting all his mazda 3 parts it turned out that his ignition module was bad.. good luck, hope yours would be fixed soon.
I am having this same problem but with my truck. I have been researching it a lot today and it seems like a pretty common mazda problem actually. I have done a bunch of crap to my truck with no results including the ignition module, fuel filter. battery, plugs/wires, and engine coolent temp sesor. Over all I think you might have the same demon possesing your car that is possesing mine. Good luck and let me know if ya ever fix it.
redpeppers
03-25-2006 03:08 PM
