mazda doesn't crank
Old 01-03-2009 | 02:59 PM
lynchvm's Avatar
Default mazda doesn't crank
I have a Mazda 626, 4 cyl, 2001. The car doesn't crank when I turn on the ignition. The starter motor/solenoid checked out OK at an auto parts store (O'Reilly's). When I turn the key I can hear the solenoid click but the starter motor won't turn. Any suggestions as to the next step?
Thanks,
Vince
Old 01-14-2009 | 10:04 PM
tommyatv's Avatar
Default RE: mazda doesn't crank
make sure the battery is good and the connections are clean and tight. if all checks good then it's probably the starter.
Old 01-14-2009 | 10:37 PM
sstlaure's Avatar
Low voltage or a poor ground would be my guess.
Check both the ground wire on the starter as well as your battery cables for any signs of corrosion build-up.
Old 01-18-2009 | 12:41 PM
darx's Avatar
eliminate first that the starter isn't faulty buy simply giving it a few gentle taps on the side with a hammer or something else... if the car starts after that... theres your answer...
DanVoss911
06-17-2015 03:31 PM
jmr94
12-01-2014 10:53 AM
rjonez
01-06-2010 12:53 AM
dsmx
01-26-2009 10:42 PM
Paul T
01-05-2009 09:52 PM
Quick Reply: mazda doesn't crank
