Mazda3 Throttle Bouncing Randomly???
The throttle started bouncing in my 04 Mazda 3 Hatchback Manual Transmission for some reason. It does it intermittently at random. If I turn the car off and restart it, the problem goes away for a bit and then comes back eventually. Most days it doesn't do it at all. Occasionally it happens. Any ideas would be appreciative. The car as about 100k on it. I recently cleaned the Mass Air Sensor and didn't see any improvement. Again, this throttle bouncing only happens from time to time. Thank you so much for any advice
Video of the throttle bouncing:
http://s203.photobucket.com/user/mer...0b983.mp4.html
Versicom: I had a similar issue with my Ford Windstar. It is actually only the tachometer that is bouncing, there seems to be nothing wrong with the throttle.
I took the instrument cluster out and took it apart. There is a housing with the light bulbs, a printed circuit board and another board with stepper motors for the tach and the speedo, then there is a faceplate and the lens.
I could see nothing wrong on any part, but after putting it back together it worked fine. My conclusion is that some contact was affected by a little corrosion.
If you take it apart do not remove the hands from the stepper motor axles. On the Windstar they are not keyed. I had to do some guess work to get the hand in the right position.
Jolza
12-05-2023 06:37 PM
