mazda6 on 92 ron fuel
Old 02-05-2009 | 02:45 AM
jopey12's Avatar
Default mazda6 on 92 ron fuel
Mazda6 Supersport aug 05 30,000 km
I was wondering if anyone else has found that the 6 runs more smoothly on 92 ron fuel rather than the required 95+ron. We have a shortage of premium fuel at the moment, so I had no option but to use regular unleaded. The engine runs much more smoothly, and gear changes (manual) also smoother.
Are there any negative effects if i keep running this fuel?
Cheers
Old 02-05-2009 | 06:47 AM
shipo's Avatar
Cheers
What you are most likely experiencing is the lower power your engine is producing. When you run a fuel that has a lower anti-knock rating than what the engine was designed for, the ignition system senses "knock" and effectively de-tunes your engine by delaying spark timing (and valve timing as well if your engine is so equipped). The effect is that your engine will feel a bit smoother as it isn't producing as much power.
Long story short, the negative effects of running this fuel are slower acceleration, and lower fuel economy (you'll probably notice a mileage dip large enough to actually make running the low octane fuel more expensive per any given distance than running Premium fuel).
Old 02-10-2009 | 12:45 PM
wildtay's Avatar
Ok, I have a 2003 Mazda 6 4 cyl. should I be using premium? or just the regular gas? I never though of this before but my guess since I do not have the v6 would be that it didn't matter right?
Old 02-10-2009 | 01:18 PM
shipo's Avatar
The short answer is, "Use the exact fuel your Owner's Manual recomends, no better, no worse." That said, given the compression ratio of your engine, I'd "SWAG" that you should probably be using "Regular" fuel.
Old 02-10-2009 | 04:02 PM
87 Oct. Anything else is a waste of your money and potentially hazardous to the emissions control system in the car.
I bumped up the timing a bit on mine, and living here in Texas it gets quite hot and often dry in the summer months. When that happens, I usually compensate by mixing in SOME 93, or if I'm lazy, filling up with 89 every other tankful. That seems to do it.
AntonA
08-24-2009 03:49 PM
Variety=Spice
10-11-2007 11:14 PM
UrbanmanUSA
08-04-2007 04:14 PM
1993mazdaMX6
03-31-2007 11:41 PM
ATL-
04-14-2004 04:04 AM
Quick Reply: mazda6 on 92 ron fuel
