missing hose on capella
Old 03-30-2008 | 11:55 AM
Sirob's Avatar
Default RE: missing hose on capella
One more picture from 626 GE manual. There is part # 13-104J and itlooks likejust small cup for this nozzle. Perhaps you had such a cup.
[IMG]local://upfiles/5111/3F13A1549D0E4FE994F0910BBB278FCD.jpg[/IMG]
Old 03-30-2008 | 12:20 PM
Sirob's Avatar
virgin1, in general, Capella is Japanese nameof 626forlocal Japan market
Old 03-30-2008 | 02:26 PM
Mathew_lincoln's Avatar
I will check the egr valve this evening when I get home from work, thankyou. A Capella is the japanese market equivalent of a 626, or so I am told. Ours is a 1.8 Auto which until now has been good, apart from when it was imprted into NZ a few years ago they pressure washed the engine and the spark plug wells in the head must have filled with water, this slowly coroded the contacts to the spark plugs, difficult to see, causing a persistant and alarming missfire.
Old 03-31-2008 | 04:51 AM
Sirob's Avatar
Just found photo & part # of this cup
[IMG]local://upfiles/5111/3C127F92F4EA47AE8222E3EF5D4F8A30.jpg[/IMG]
Old 03-31-2008 | 02:35 PM
Elaine's car, a 1996 1800 mazda capella imported from japan as a used car doesn't seem to have a EGR valve, I pressume this is used in the emmision control system in America and similar markets. I looked where it appears to be fixed, under the throttle body and nothing. I am now going to assume that this nozzle should be blanked on this car. I will now try the standard stuff for running rough just after a service, I will replace the spark plugs again, just in case I fitted a bad one, and then the plug leads as they are disturbed when you change the plugs so may have been damaged. Does anyone know if the distributor cap, and rotor arms are service parts on this car, not disturbed but they may be next before giving in and taking it to a garage. I was an engineer, and now lecture management so going to the garage is a last resort for a bored and frustrated engineer. Thanks for all your help I will report back when it is sorted.
Old 04-01-2008 | 04:07 AM
Sirob's Avatar
Mathew, just FYI. It is possible that Capella has EGR. Please see two photos of this valve on Mazda Capella Wagon FS-DE, ATX, 1999. Also, I today received info from one guy who tells he has similar nozzle on his airbox and the hose from this nozzle goes to EGR valve. But his car is Mazda Capella Wagon GWFW 2.0 Turbo DIESEL
[IMG]local://upfiles/5111/66EE9B50D8F04BA98F4C358868856BBE.jpg[/IMG]
[IMG]local://upfiles/5111/F40C414BB3F24049915521DD2C934BD7.jpg[/IMG]
Wylee miata
07-10-2015 02:44 PM
kenviv
02-04-2013 09:09 AM
vernievern
08-24-2010 05:48 AM
ashkumar
01-04-2010 11:00 PM
BSmack
07-19-2007 05:04 PM
