Mixing Gasoline
Old 09-26-2005 | 04:23 PM
the_gray_mazda6's Avatar
Default Mixing Gasoline
is there a certain amount for mixing two gasolines together, like regular vs. plus gas? would a 50/50 ratio be good or does it not even have to be that high. I roll with a 05 Mazda6 3.0L. Or should i just completely run Plus gas instead of the cheap stuff? does it really make a difference at all?
Old 09-26-2005 | 07:59 PM
Patrick's Avatar
Administrator
Default RE: Mixing Gasoline
what does your owners manual call for? i would guess 89 octane...the only people whom i have seen run a mix are very high performance cars...in which case they are mixing high octane (100+) with high octane pump gas, because 93 isnt enough for them
Old 09-28-2005 | 03:18 PM
owners manual says 87 octane.... if i were to use a higher octane like 89, would that be better for my engine?
Old 09-28-2005 | 06:59 PM
Patrick's Avatar
Administrator
octane rating has to do something with the level of detonation...i have an article about it, but it is about 15,000 words long...
anyways, your car may run a little better with a higher octane..i dont think that it would hurt anything, as your car has knock sensors to prevent things like varying octane...so forth
Old 09-28-2005 | 08:13 PM
bkey71's Avatar
It is best to use what the manual calls for. The engine computer is calibrated to run on 87 octane. You can run 89 or 93, but you would be basically wasting money. My mom's VW Passat calls for 91 which must not be available in TX, so she fills up with 89 one time then 93 the other. She waits til it gets about a half tank and alternates on fill ups. And most people think higher octane burns hotter and faster, but it's quite opposite, the higher the octane rating, the slower and more controlled burn in the combustion chamber. That's why pinging tends to be less of a problem in hot weather when you step up a grade in octane.
Old 09-29-2005 | 11:34 PM
yeah, i mixed 89 octaine with 87 and the pinging sound has been eliminated. My performance feels to be better as well. Especially when accelerating. Would this be a result of the higher octane gas? The ride for whatever reason seems to be smoother.
Old 09-30-2005 | 08:14 PM
bkey71's Avatar
Pinging, or also called pre-ignition, is caused by high combustion chamber temps. This is the reason for an EGR valve, it opens to allow exhaust fumes in the engine to cool it and reduce NOX at highway speeds. The higher octane is a slower, more controlled burn, which can lead to better performance in some cars. As far as the ride, dunno. My cousin swears when he washes his car it runs and drives better!
Old 10-01-2005 | 08:42 PM
nj85z28's Avatar
idk, my GTP manual states running less than 91 octane could blow the supercharger
Old 10-02-2005 | 12:56 PM
hey bkey71, does the mazda6 have an EGR valve already on it or do i have to go and purchase one?
Old 10-02-2005 | 09:50 PM
bkey71's Avatar
I am not sure about having one on your car, I would presume it does...I know babyhuey would know for sure. An EGR valve is not something you add yourself, it is a piece of emissions equipment from the factory. It means Exhaust Gas Recirculation valve, "EGR".
Quick Reply: Mixing Gasoline
