Mixing Gasoline
RE: Mixing Gasoline
I don't know of a way to completely eliminate pinging. I know in most every GM owners manual it says "some pinging is normal, only heavy knocking noise means a problem". I paraphrased it there. Your car is completely computer controlled and i doubt there is any adjustment that can be made. Example: Rotate distributor to retard timing a few degrees. You can try to step up and try to run super for a few tanks and see what happens. I have had no problems with shell gas here, it is mainly up to the station owner to keep their underground tanks dry and clean, not the refiners.
Tony88
07-24-2009 07:58 AM
