no spark
Old 12-02-2012 | 04:32 PM
Protege23's Avatar
Default no spark
Still cant get this car started. Mazda protege 1.8. Coil is good crank sensor is good tested ohms on cam sensor its 1051ohms so im pretty sure thags good. Grounds look good still no spark. Main fuses and relays are good. Any idea guys
Old 12-02-2012 | 05:33 PM
Kevinkpk's Avatar
How are you checking for spark?
Old 12-02-2012 | 07:40 PM
Protege23's Avatar
Pulling wire off plug, putting a new plug in wire and laying threads again motor to ground it. Then cranking
Old 12-02-2012 | 07:50 PM
Kevinkpk's Avatar
I use a #2 phillips screw driver instead of a plug, but ok. Make sure the plug has a good ground.
Old 12-02-2012 | 07:53 PM
Protege23's Avatar
Did the screwdriver as well. No luck
Old 12-02-2012 | 09:07 PM
Kevinkpk's Avatar
Does it have a power train control module, asking? If so that is what I'd be looking at
Old 12-02-2012 | 10:32 PM
Protege23's Avatar
Yes it does just unsure of how to test it
Old 12-03-2012 | 12:46 AM
tanprotege's Avatar
Replace with a known good one.
Old 12-03-2012 | 01:29 AM
Protege23's Avatar
That's an 800 dollar part I want to b sure
Old 12-03-2012 | 02:10 PM
tanprotege's Avatar
See if a junk yard can help you. Offer to pay a restocking fee for a returned item.
