P0402 & no start when hot - Miata 2000
Old 09-17-2007 | 01:14 PM
2000gal's Avatar
Default RE: P0402 & no start when hot - Miata 2000
I didn't realize at the timewhen giving an update here onfriday's posting, but guy running code check at Advanced Auto must have clearedcodes ascheck enginelight was off when I left there and remained that way untilsaturday.
Returnedto Advanced Autotoday to re-run OBD and now both codes are showing up...the P1345 and the freakin' P0402 EGR Flow Excessive code has returned. When we removed the EGR Valve to clean and replace gasket, we did not check the little valve inside to see if it wasmoving freely or perhaps sticking- so guess we need to removeEGR Valveagain and specifically check this.
Any suggestions on the return of P1345 code? Thank you!
Old 05-16-2008 | 11:37 AM
paulorlo's Avatar
My car is also exhibiting the no start when engine is hot and turned off syndrome. The code is also P1345 which is a misfire code. Check engine light will go off if condition is not repeated the next couple of start ups. I have changed the spark plugs and the ignition wires. Don't know if this will fix the problem. I have a 2000 Miata with 40,000 miles. Let me know what you find to be the cause. Thanks and good luckk.
Old 05-24-2008 | 10:54 AM
woodurb69's Avatar
the p0402 code is usually a clogged vacuum port that those vacuum lines are hooked onto the (surge tank) intake manifold. usually a drill bit in to the metal nipple on the intake will unclog it. plus the egr port directly behind the throttle body (you have to remove it) will also clog with corbon.
the other code is a Camshaft position (CMP) sensor circuit malfunction. this can be caused by an unconnected crank or cam pos. sensor anytime while cranking. or it could be a failing crank sensor. did you recently have the timing belt done? they could have damaged the sensor, wires, or crank trigger wheel.
the starting issue and misfiresare almost always a coil issue. the ignitoin module is not on t coil though. it is pcm controlled & not a separate unit or anything. i would replace the ignition coil. i've seen bad wires & plugs cause the ign coil to fail.
Old 07-18-2010 | 07:02 PM
Forest42's Avatar
Default Hard Warm Start fixed
I had this same exact problem. Just hard starts with warm car and hot ambient temps. I also had the EGR valve error code. I replaced the cam position sensor and it fixed both problems. The car starts fine in all situations and my EGR valve engine code went away. I have some photos on my site.
Last edited by Forest42; 07-18-2010 at 07:03 PM. Reason: addition of more information.
Old 09-10-2010 | 04:01 PM
Shaund99's Avatar
Default 2000 Miata
Changed Converter, coil packs, o2 sensor and plugs and wires.... the check engine light came back on!!!! Can anyone help me out as it is driving me crazy!!! only 29k miles on it...
Help!
Old 09-13-2010 | 10:10 PM
Forest42's Avatar
Help!
Well read my last post. :P CAM pos sensor fixed it all for me. I had replaced most of those things also.
pony5o
09-11-2010 12:18 PM
dkvarda
10-26-2009 11:05 PM
red_9782
06-10-2008 09:38 AM
amurphy
10-18-2007 09:58 AM
tlavely
05-05-2007 07:28 PM
