Sea Foam
Sea Foam
Was reading another forum site about using Sea Foam. Seems to be some who think it is great and some say just pour in kerosene or diesel (they are the ones who think Sea Foam will do harm). Is there a chance of damaging catalytic convertor (by sucking 1/3 of bottle into vaccum line of brake booster). Also, if 2/3 of bottle is poured into crankcase is there a chance of any internal damage - bearings, sensors, etc.?
RE: Sea Foam
From a previous post: 929 WAS running BAD (answer was)
Any vacuum line that has vacuum at it when removed goes back to the intake manifold. Once inside the intake manifold the next place it will end up is the intake valves before it enters the combustion chamber. If carbon was keeping the valves open and this was the cure then a product called sea foam works very good. See link below to what it looks like. This product is a liquid and not a spray so needs to be introduced into the intake system slowly so as not to hydrolock the engine.
http://www.partsamerica.com/productdetail.aspx?MfrCode=SEF&MfrPartNumber=S F16&CategoryCode=3233
< Message edited by babyhuey -- 4/20/2007 7:21:10 PM >
Got someSea Form today - 2 cans... It is safe for oxygen sensors. Thanks babyhuey - Roy
RE: Sea Foam
Here's the MSDS (Material Safety Data Sheet) for it.
http://www.montanajacks.com/msds/seafoam-msds.pdf
It's made of Pale oil (highly refined oil), Naptha (Petroleum Ether), and IPA (Isopropyl Alcohol.)
Your car will smoke while it's burning it, but once it's cleared out there shouldn't be any lingering effects. If it cleans up deposits and shoots them out the exhaust, then great.
