TPMS Swap
Old 06-18-2010 | 12:52 PM
marcusdarling's Avatar
Default TPMS Swap
Hay there,
did a bit of searching and it seems like this could work but just want to ask to make sure.
I have an 07 Mazda3 2.3 and I bought some 08 Mazdaspeed3 OEM 18 rims and slightly used tires. They did not come with the TPMS (tire pressure monitor system) stems installed. The seller told me it came with TPMS but the stems are just regular rubber stems so I am assuming they are not there.
My question is can I take the old ones off my 16" mazda rims and put those on my new 18" mazdaspeed rims? Guy at tire store said you could not or if you could the computer would have to be recalibrated but he didn't seem like the ultimate authority on the matter.
If possible would you guys do it? or is it not worth the hassle and $$ to have the tire store swap them out.
I would like to do it soon as I am going to sell the old rims and just want to make sure to take out the TPMS if I need them.
thanks
-m
Old 06-20-2010 | 12:01 AM
tireboy's Avatar
make sure you check the rubber seal after the sensors are installed in your new wheels..yes you can swap em over...some tire stores frown on this . i do them as per customer request .. set the air pressure as per the drivers side door jamb sticker...you will be fine..
Lupae3s
10-08-2007 02:17 PM
janz
12-06-2006 11:35 AM
Jim Rowley
10-09-2006 05:59 PM
MrSpike118
03-30-2006 02:32 PM
Lupae3s
03-24-2006 07:28 PM
Quick Reply: TPMS Swap
