Transmission Flush vs. Drain and Refill
Old 07-30-2009 | 12:13 PM
93greenstrat's Avatar
Default Transmission Flush vs. Drain and Refill
I realize that simply draining and refilling your ATF does not remove all of the old fluid, but if your tranny is in good shape and has been well maintained otherwise; is there any reason why you should go for a flush (of fluid exchange) instead?
Old 07-30-2009 | 12:56 PM
vlstellato's Avatar
Flushing the system is good( if you don't have a tranny filter) because it removes all the old fluid from transmission lines and cooler, you don't want to contaminate the new fluid. If your car has a tranny filter its not recommed to have a flush because the old tranny filter is full of old fluid and contaminates.
Old 07-30-2009 | 05:29 PM
shipo's Avatar
Over the years I've been following this whole Tranny Flush vs. Tranny Service debate, and I have to tell you, more often than not, those who've opted for the flush end up opting to buy a new transmission a few thousand miles later. Fastest way I know of, of effing up an automatic transmission.
Save yourself thousands of dollars and have it serviced the way Mazda recommends you have it serviced; drop the pan, change the filter, put the pan back on, and fill're back up.
mattattack811
01-08-2014 03:07 AM
Kevin McCutcheon
09-10-2013 06:21 PM
FollyFollyFolly
10-24-2011 07:44 AM
andy936867
11-21-2007 05:56 PM
S1CkM6
06-25-2006 06:40 PM
Quick Reply: Transmission Flush vs. Drain and Refill
