tube for 17 in tire
RE: tube for 17 in tire
I doubt you could even find a tube for one.
You don"t say what"s cracked, the wheel or the tire, but if it"s the wheel I would get that fixed or replaced right away.Cracked, low-pressure cast aluminum is nothing to mess around with. That could very well be a safety issue that could affect you, any passengers and any other driver"s that may be in the area should it fail.
Modern "tubless" tires are not designed to offera hospitable place for tire tubes, they are just way too rough, and they will cause the tube to catastropically fail with no notice.
