1991 mazda 323 helicopter sound
Hi. I was wondering if anyone can help me. My 323 runs really well but one day there was a sound coming from the engine like a helicopter. What could be the problem? I just filled the coolant and was totally empty when I looked at it.
Oh, what about the white smoke? Wet plugs? Compression seems OK? Any pressure pulses you can feel when you cover the rad filler with your hand? (NOT with the engine hot please!). Where the hell is that water going? If it's not dripping out of the bottom of the engine or rad, or being peed out of the exhaust, its got to be still there, right?
Well, if your water pump bearing or gasket went, a timing belt running behind a timing belt cover filled with half a rad worth or so of water would probably make a really odd sound, eh? Like SCHWOOM, SCHWOON, eh?
Better check your dipstick too, you could have an oil pan with more water than oil in it. If you drive around with a sump load of water you will soon destroy you engine.
xDread92x
06-30-2014 05:07 PM
