2002 626 intermittent electrical power loss
Old 08-04-2010 | 08:36 PM
dantheman602's Avatar
Question 2002 626 intermittent electrical power loss
I have an intermittent starting problem. I can turn the key into the on position and things are normal, bells and whistles and such. When I turn to the start position it loses electrical power, clock, radio, lights etc. Turn it off and cycle through again, and the same thing. I jumped it and it started right up. then I had the battery/alternator tested and it is believed to be ok. I drove home and cycled on and off about 4 times and repeated the problem. I left the key in the on position for a minute or two and then all the bells and whistles returned like normal,even starting. Cycled a couple times again, and of course repeated the problem of no electrical power. This is my itermittent issue. Any ideas?
Old 08-27-2010 | 07:09 PM
mc_zoom's Avatar
Since you only had the two tested, I would actually replace the battery and alternator. Those would be the obvious. If that doesn't fix it then move onto fuses or make sure your ground wires are still entact.
zildjian71
08-22-2013 10:04 AM
Dave Clouse
03-09-2012 07:28 AM
ChrisFilter
11-06-2011 09:45 AM
kyushu2002
12-09-2010 09:38 AM
rabirza
07-18-2007 12:36 AM
Quick Reply: 2002 626 intermittent electrical power loss
