3 cylinders
Old 01-14-2009 | 03:49 PM
jotrent's Avatar
Default 3 cylinders
have a 1996 4 door hatch - it sounds like its running on 3 cylinders - there's no coolant in the oil - it runs (just won't idle) have replaced the spark plugs and leads- dropped valve? ehat do you think? Thanks
Old 01-14-2009 | 07:02 PM
sstlaure's Avatar
Default RE: 3 cylinders
Do a compression check (gage screws into spark plug hole.) Don't start the engine, just crank it over.
If you've got a dropped valve or bad rings, that will tell you which cylinder to go after. Just look for wide variation from cylinder to cylinder.
Old 03-07-2020 | 08:13 PM
Liz Browne's Avatar
Did you fix it? A faulty injector will make it run on 3 if the spark is ok. Obviously the fuel pump is ok cos the other 3 cylinders work
XxStirCrazedxX
09-17-2012 07:52 PM
betard_foosier
07-26-2011 06:41 PM
HolyGhost23
05-26-2009 10:03 PM
fajitafrog
10-04-2008 12:46 PM
rcampora
04-21-2008 01:34 PM
Quick Reply: 3 cylinders
