626 fails to start when hot. dealer perplexed.
Old 08-27-2007 | 01:12 PM
hixx's Avatar
Default RE: 626 fails to start when hot. dealer perplexed.
There is a check valve in the fuel pump that lets the fuel system retain residual pressure. Typically 15 psi or so. If a pressure regulator sticks on the high pressure side it slams the check valve with a higher than normal pressure. This eventually causes the valve to imbed itself into the seat and now the fuel pump has to overcome this excess residual/seated pressure which causes the pump to draw excessive amperage. If i see a bad fuel pressure regulator i always inform the owner that their fuel pump is probably short for the war. The most common cause of a bad regulator is fuel contamination. Water etc.
ryanbarrett
04-19-2013 07:25 PM
04nordicgreenrx8
08-19-2008 09:01 PM
mazdawoes
09-16-2007 09:28 PM
GTFORZA
06-19-2007 09:30 PM
GTFORZA
06-19-2007 03:30 PM
Quick Reply: 626 fails to start when hot. dealer perplexed.
