626 Temperature Gage Problem
Old 11-07-2009 | 02:52 PM
jobeck1's Avatar
Default 626 Temperature Gage Problem
I have a 1996 626 with 290,000 miles, and a couple of months ago I had the water pump and hoses replaced. About a week ago the temperature gage started to act wierd. When I turn the key on the gage automatically goes to the warmed up temperature reading and stays there. It does this all the time. Is this just a bad gage and would it even be worth replacing it? The gage needle does move, because when I shut off the engine it goes down. I'm not too concerned since I just had the work done and am not too worried about overheating. Any ideas would be greatly appreciated.
Old 11-08-2009 | 04:38 PM
projexladen's Avatar
since the gauge is moving, i would bet it's ok. i would suggest testing the temperature sending sensor for the gauge. note: there are two temp sensors (maybe more for fans, i can't be sure on your car), one for gauge, other for ecu. on 94 mx3, ecu's sensor was called a thermosensor. find the other one, and test with ohm-meter, with that high mileage, it could have gone bad... it's probably cheaper to replace than the gauge itself
Rocketspecial
05-29-2017 03:35 AM
626dad
05-07-2008 07:07 PM
bluemikecheck
10-31-2007 01:33 AM
ancsa
08-20-2006 05:37 AM
banjman
06-23-2005 08:44 PM
