626 Won't start
626 Won't start
Hi all,
I am new to this forum. I just bought a 1993 Mazda 626 it was running fine until the other day i shut it off and tried to start it a short time later it took a few times of cranking to get it to start.Again i drove it a few times with no problems.I than drove it about 5mi shut it off went to start it a few hrs later it would'nt start. I turn the key its turning over but won't start.I am not getting any spark to the plugs. I replaced the plugs,wires, cap and rotor still no luck.I was wondering if anyone experienced a simular problem and how did they fix it. Its starting to get costly PLEASE HELP! Thanks, Randy
RE: 626 Won't start
Please see this post >> WON'T START. It might be the igniter in the distributor.
RE: 626 Won't start
Sounds like a pretty good probability there bkey. Did not see info about if was a v6 or 4 cyl but the v6 distributors were notorious for failing and loosing spark at random times. They would either stall after warmed up or not restart on a heat soak. Would usually always restart after 5 or 10 minutes.
RE: 626 Won't start
I hate bad news. But in your case the ignitor is not available, at least thru mazda, as a separate service part.[:@] Coil and ignitor were made available as separate on the v6 but was never done on the 4 cylinder distributor. Cap and rotor are pretty much all you can get outside of a complete distributor. A new one runs about $615 while a reman unit retails for $445. Good used or aftermarket may be available as well. Sorry.
RE: 626 Won't start
Thanks for the info i found that to be the case as everybody i talked to in the parts store said the same thing.I thought it was a lost cause but someone was looking out for me i found a complete remanufactured distributor on e-bay for $60 and it works yippee Thanks for all the help. Randy
greggstonecipher
03-30-2007 12:17 PM
cugene
03-29-2007 08:07 PM
