94 mazda 323 torque converter--help!
Old 09-27-2011 | 06:56 PM
garybat's Avatar
Default 94 mazda 323 torque converter--help!
I have a 94 Mazda 323 that I think is having a problem with the torque converter or one of the parts close to it. I have no idea where the torque converter is. I want to unplug it and see if it stops the problem. The car stutters and dies whenever I put it into reverse or drive and don't give it gas immediately. It's also dying when I come to a complete stop. So I'm having to shift it in and out of neutral just to get around town. Anyone know where this part is or have a similar problem that they were able to fix?
Old 09-28-2011 | 04:54 AM
crazy202's Avatar
the torque converter is the part that goes between the engine and transmission, same place as a clutch on a manual car, if there is a problem with converter the transmission has to come off to get to it, not a simple plug sorry matey.
try checking the fluid level in the transmission, may need topping up.
an automatic transmission runs purely on hydraulic pressure. no fluid - no pressure, thus the "gears" will not drive properly.
Hope this helps.
Cheers
Old 09-28-2011 | 05:02 AM
crazy202's Avatar
although reading it again, may be an issue with your engine.
you say the car dies when you come to a stop? i wouldn't thing that would have anything to do with the transmission as its not easy to stall an engine with an auto, not saying you can't but its not a common thing at all.
what makes you think its the torque converter out of interest?
cheers =]
Old 09-29-2011 | 07:34 PM
garybat's Avatar
Default Let me repharse this......
The vehicle dies as soon as you put it into gear. It is acting like a torque converter clutch problem (ie not unlocking). Does this vehicle have a lockup clutch in the torque converter?? If so, where is the wire located so that I can disable it?? On some small GM vehicles, I can disable the TCC externally. If not, then I can drop the pan to do it.
The fluid is full & the engine runs great. If anyone has any ideas, your input will be greatly appreciated. Thanks in advance.
Old 10-13-2011 | 05:00 PM
matthew.dutton's Avatar
hey yall- first post here lads. I'de recommend checking the vacuum your engine's generating. If you have a vacuum leak it is very common for autos to stall out at idle. If it's been a while since a timing check has been done i'de give it a quick check too. hope it helps
Jaspet
04-24-2021 07:53 AM
kct
02-12-2010 08:33 AM
mech323
08-03-2008 02:54 PM
FreakinToddles
03-31-2008 07:37 AM
biggablunts
05-03-2007 06:08 PM
Quick Reply: 94 mazda 323 torque converter--help!
