98' 626 grind...
98' 626 grind...
Ok, so it's a 1998 mazda 626. I was driving and heard what sounded like something falling off the car and scrapping while driving on the highway. I looked under the car nothing is out of place. I drove it home and thought maybe a brake pad broke, did the brakes and it didn't fix it. I can put the car on jack stands with tires off and if I put it in gear it sounds like a terrible loud grinding coming from the wheels/behind motor somewhere in that area. I won't even drive it as it is. Any ideas on what i could be? I'm not familiar with mazda cars.
That's a possibility, they can make some bad noises too. check the cv axle boots for tears, both inner and outer. Most of the time a cv acts up, a boot has torn and dirt and other contaminants get inside, screw up the gears eventually. Easy way to tell if the outer is going bad is clicking when you turn.
I wouldn't rule out wheel bearings though, they're always nasty and loud when they're going out. Can be very dangerous too
