alternator running at only 12 volts
RE: alternator running at only 12 volts
It sounds like an alternator problem It should be running about 13.8 - 14.5V. As long as all connections are tight on the battery and alternator and the fuses are good, I would plan on buying one.
I agree, usually when it reads low like that its bad, almost positive since you already replaced the battery.
TEST
While the car is running diccontect the negative battery cable if the car stops running it is most likely the alternater.
This means the car is relying on the battery alone to produce current for spark and by removing the battery cable you tested to see if the alternater was producing enough power to keep the car running. If this is true your driving time is limited to how much juice the battery has left and that wont last long.
Some auto parts store will test for free a load tester for the battery they can do this while its in the car or out.
they can test the alternater also on a bench tester, pretty sure you have to pull it out first.
TEST
ORIGINAL: Larry 62694
TEST
TEST
mykelp
03-29-2012 05:13 PM
